Will try removing springs to see if it closes right. The pivots seem tight ( not sloppy)...it worked okay before so I can't understand them being worn now, but will try as you sugguset..
Yes the hood was taken off when I removed the engine/trans...We have tried adjusting it every way we know..still humped up at the cowl area, will go down with a push....
Thanks guys, still looking for a solution...
