There will be no ujoint issue with a torque tube rearend because there is only one, and you will be decreasing the angle. As long as it doesn't hit anything you will be fine. You may want to check that the splines on the front end of the torque tube are clean enough, though, or it may not retract enough when you hit a bump and you may bend something.
Paint & Body Shop moderator
