| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I almost never find a pump that needs to be replaced. Low oil pressure gets blamed on oil pumps all the time but it is seldom the pump. If the shaft is not loose in the housing and the gears are not badly scored it will go a long time.
See the USA in your vintage Chevrolet! My Blog | | |
