| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Find a NAPA store- - - -they either have a lot of the old stuff in stock, or they can order it on short notice. Have you done anything about those widowmaker wheels yet? If it's got a Hydrovac brake booster, that's a possible place the fluid is going. They're bad about leaking fluid into the vacuum chamber and never showing an external leak, and rebuilding one is a real pain! Fortunately, they're not too expensive as a rebuilt exchange unit. If the wheel cylinders are leaking, there will be wet brake fluid stains on the inside of the front tires, or between the rear duals. Jerry
