| | | Forums66 Topics128,048 Posts1,055,664 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The axle is an open knuckle Dana 44, pretty much the standard axle used in GM 1/2 and 3/4 ton 4x4s from '70-'87 (HD option after '77). Sounds like it mght have a set of mismatched lockuots. As far as value, have no idea. It would be worth more if you have the rear axle that goes with it, and sell them as a matched set.
Bill Burmeister | | |
