I want to piece meal the kit for several reasons. So, I think the bracket kit I purchased assumed using a 5 lug rotor/hub assembly. I want to reuse my hub with rotor that slips over wheel studs. So, I think to add roller bearings to my original hub require the special and expensive bearings. Or, is there a 6 lug rotor/hub that would work with standard bearings?
