| | | Forums66 Topics128,161 Posts1,056,956 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If your sandblasting your truck why are you using POR 15?
Por is for covering up rust (encapsulating), epoxy primer is for waterproofing and chip resistance on clean metal with no rust. Both work on the intended surface (Por needs rust, epoxy needs clean metal)) and neither works on the other... A self healing "Seam Sealer" is wax based and would go over epoxy not under, Por-15 I'm not sure about.
Give me ambiguity or give me something else
