reddie - it depends on the year what the exact differences are, but generally, the big bolt fenders are wider, have a larger wheel opening and a slightly different shape at the front to accommodate the much bigger wheels/tires - grilles may also be wider and higher .... a big bolt front clip on an S10 chassis will look very out of place
you can check the GM factory specs for
your year here to see differences in measurements
