| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bert, At the bottom of this page is an illustration of what 3B described. Is your 53 still 6v, or was the car engine you had in it a 12v engine? The 1958 engine would have originally been 12v. If the engine you are removing was 6v, you should use its flywheel and starter. You could use either engine's complete clutch assembly, as long as it can be bolted to whichever flywheel you will be using (use the throw-out bearing with its matching clutch assembly). | | |
