2 members (Oswald, Brian Moore),
139
2
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Could be. The vacuum advance works when there is some vacuum to operate it. In a larger truck under a load there may not be enough vacuum to operate it. The mechanical advance in that distributor will do the timing advance instead of depending on a vaccuum advance.
Even in the half ton trucks if the throttle is wide open under a load (pulling a long steep hill) the vacuum advance is all but useless. The mechanical advance takes care of the timing.
