1 members (baldeagle),
27
2
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I guess you can set just the bare distributor in and turn rotor till the drive tang drops into the pump slot and mark or measure to a place that won't be covered by the clamp assembly. Remove and reinstall with clamp and plate in place and see if it drops down to your mark or measurement. I was thinking the housing had a step that stopped the distributor at the top of the clamp to give correct spacing but it's been many years for the old brain to gather cobwebs.
Evan
