3 members (panic, 2-Ton, 1 invisible),
133
3
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88483 08/04/2003 1:28 PM | Joined: Dec 2000 Posts: 25 Member | | Member Joined: Dec 2000 Posts: 25 | If you will hold your alternator so that you are looking at the back L1 will be to the left, L2 will be to the right. The original plugin had the small cut out for the lock to lock in place. Again, the L1 will be to the left, L2 to the right.
1950 3100 5-window
