| | | Forums66 Topics128,120 Posts1,056,319 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Rod bearing clearance has no effect on oil pressure on a splash engine but should be checked while in there. You will most likely need to pull shims on the mains to improve the pressure. The oil pump relief valve is set at 14 psi so that should be max when warm, about 7 psi at idle if all is set up correct.
See the USA in your vintage Chevrolet! My Blog | | |
