2 members (Rusty Heaps, 2-Ton),
88
3
Mod | | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88330 11/18/2001 1:39 AM | Joined: May 2001 Posts: 4 Member | | Member Joined: May 2001 Posts: 4 | Well I finally fixed the gas guage on my 62. It stopped working one day while out four wheeling in the desert. The other day I ran out of gas about a block from work so that did it. I got the trusty manual and did the checks that it says and all things were pointing to the sender. I removed it and found the metal strip missing a chunk that I guess is in the bottom of the tank. I didnt want to buy a new sender because the money is tight so I cut a length of 16 guage wire and removed the insulation and soldered it to both ends of the sender in place of the metal strip. I hooked up the wires and then moved the float to the top and then slowly down to the bottom and I will be darned. The dang thing works. Saved money and gained knowledge. Cant do that to these new cars.
Everybody was born crying, most of us get over it.
