| | | Forums66 Topics128,271 Posts1,058,416 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88201 09/04/2004 7:45 AM | Joined: Jan 2004 Posts: 32 Junior Member | | Junior Member Joined: Jan 2004 Posts: 32 | You need to check the wire going to the + side of the coil, if this wire has voltage with the key off you need to find where the voltage is coming from,the coil should not have power with the key off. If you disconnect the battery with the engine running the engine will continue to run as long as the alternator is charging, but doing this can damage the alternator. | | |
