| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88186 01/24/2005 4:11 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The amp meter tells you current is flowing, which does not always mean something is wrong.
If your amp meter is showing negative when the lights are on it means your truck is wired so that current to the lights is going through the guage.
That may or may not be a problem.
If you are using the stock amp meter your alternator may be able to produce enough power to burn out the guage. But unless you are running some accessories that use lots of power you are probably okay.
What wiring diagram did you use to wire your truck?
How is the alternator wired? Is it wired as a '1-wire'?
If your headlights don't pull some current they are burned out or disconnected. What that means to the amp guage depends on how things are wired.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
