0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Progressive two-barrels were designed for high RPM (6000 or more) four cylinder engines. The small primary allows higher air velocity at low RPM for good efficiency; and the secondary allows for more CFM at higher RPM's.
Under no condition will a two-barrel of any kind work better (or even as well) on a one-barrel manifold than the one-barrel of maximum size for the manifold (the hole in the manifold is the limiting factor).
So two important considerations:
(1) Do you plan on 6000 plus RPM with your 261 (progressive 2-barrel) (2) Do you have a two-barrel manifold for your 261 (any 2-barrel)
Your comment about using a Zenith 1-barrel from a GMC 270 would be a better way to go.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
