| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87953 04/18/2002 7:27 PM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Here's how the gas gauge system works: - You have 6 volts going to the positive terminal of the gauge.
- The negative terminal is wired to the float in the gas tank
- The arm of the float has a needle that rubs across some windings (called a potentiometer)
- When the float is high, there is some resistance to ground
- When the float is low, there is very little (if any) resistance to ground
So, you can put 6 volts on the + side of the gauge and then ground the negative side. Then remove the ground. In one position, the gauge should read full, in the other it should read empty. | | |
