| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87698 04/10/2005 2:42 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | Found the problem, Bad ground on battery. I had no power at my remote selonoid and I took the ground cabe off and ground down the suface where it's attached. bolted it back on and it works. By the way the silver fuse that I was talking about is a circut braker. Now my question is that It was the horn relay that was making the cracking noise when I turned the steering wheel and the horn is not even hooked up on the steering column. Could the bad ground cause the relay to crackel because now when I start the truck I can move the steering wheel all I want and there is no noise :confused: | | |
