I've tried just about everything. I called CPP and they will send me the master cylinder bleed kit I didn't get when I ordered it. If that doesn't work I will return the master cylinder, it is under warranty. Their tech support was very pleasant, no problem if i need to send it back.
Thanks for the replies, appreciate your ideas. I know it is hard to diagnose problems without actually seeing them. But sometimes just getting a new perspective helps.
don
