This has me stumped. Problem: low to no brake pedal.
I installed a new CPP dual master cylinder with booster in my 1957 Chevy truck. It is all drums. It has all new lines and brakes. CPP said it did not need any additional valves.
It did not come with master cylinder bleeder kit, so I installed it as is and bled the brake lines at least 10 times at each wheel (starting at the outermost wheel cylinder). I bled the lines at the master cylinder multiple times, Now when I bleed any line there does not appear to be any air in the lines, I have used the pumping the brake method and a brake bleeder tool. Everything at the lines seems fine when I bleed them, but I still get no pedal.
At this point any thoughts regarding what to do next would really be appreciated.
don
