| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When you shut it off, look down the throat & blow the smoke away. See if there is any gas running into the carb. If so you have a float or needle & seat problem. Its also posible the diaphram is ruptured or not installed correctly. They are prety flimsy. Make sure it comes off fast idle when the choke is off. Have you tried slowing it down with the idle speed screw? It could be the idle mixture screw is too lean. You usually want a little more spark adfvance from the zero mark. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
