| | | Forums66 Topics128,290 Posts1,058,565 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If you take the wire loose at the sending unit does the gauge go to full? Or if you take the sending unit wire loose from the back of the gauge does the gauge go to full?
If it goes to full when you disconnect the wire at the sender then the sender is grounded. If it goes to or past full when you disconnect the sender wire at the gauge then the sender wire may be grounded some where along the way to the tank.
Could it be the power wire to the gauge is on the wrong terminal? | | |
