1 members (Hotrod Lincoln),
49
6
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87488 02/12/2005 3:32 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It could be a bad battery.
With everything turned off, pull a battery cable off the battery, and connect a DC volt meter between the battery and the cable. If you get a reading you have something using power. If you don't have a meter a cheap test light might do the trick.
With everything turned off the meter should read zero. If it reads zero I suspect your battery.
If it reads above zero start pulling fuses one at a time and checking the meter. If it goes to zero when you pull a fuse, the circuit related to that fuse in the problem.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
