To remove the HB you must pull it off via the two threaded bolt holes. The 207 HB is made in two pieces and can be damaged if pulled off using a regular jaw type puller.
During installation you must install two cap bolts to hold the two halves together before you drive it on. Don't forget to remove the bolts after it's installed.
Mike B
