Success!!! It took me two afternoons to pull off, but I successfully took it apart, cleaned it and and put it back together again. Once I put it back on my Burb I had to crank it a little bit to draw up the fuel. After that is started right up and ran great. There is still a slight bog in acceleration especially when cold, but it runs much better now. I still have some adjusting on the curb idle, high idle and electric choke to do. I re-read the rebuild manual I pulled off line and I think I can straighten it out tomorrow. The engine tends to idle really high and doesn't want to come back down to normal idle.
Anyway, I'm pretty psyched. I was afraid it wouldn't do anything once I got it back together.
See the photo of my "workbench" http://i1053.photobucket.com/albums/s461/biglarry3/b3c459c6.jpg Turns out the ping pong table that was collecting dust in the garage was good for something. You can see the Burb waiting patiently in the garage in the background.
Thanks
Larry
