7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | 123456789101112, Does your '53 non-PG engine still have the dippers on the rods and the troughs and nozzles in the pan? According to all the literature only '53 PG engines had full-pressure lube to the rods (drilled crankshaft) and insert rod bearings.... But having the rods machined for insert bearings has been around for a loooong time. Could the engine have been modified in the past? Sounds like you have 2 great running old 6's. Congrats.
Professional Novice
