2 members (TUTS 59, tclederman),
68
2
Mod | | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There's also several different 10 bolts used in both Passenger and Truck, with differing ring gear and housing sizes. They range from the 7.5/7.6 found in S10s and '78 and late mid size to the 8.6 found in late model GM trucks. Parts do not interchange exept within the ring gear size families. An option you might consider would be to find a new 3rd member for your existing housing. That will keep a reaend you know will fit right. The 3rd members will swap '55-'62.
Bill Burmeister | | |
