Right now the cost of re coring is expensive because of the cost of copper, probably over $300 to do your radiator. I just installed a aluminum racing radiator from Speedway, radiator was $129, I had to make some simple brackets but it worked great. We make a fan shroud for it also, cruised Back To The 50s and stayed at 180 degrees.
