| | | Forums66 Topics128,208 Posts1,057,452 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | I had the same problem with my 66 with a t150 rear you have to insert a small screw driver into the hole to move the adjuster lever away from the adjuster star and while holding it away use a brake spoon to the loosen the adjuster. | | | |
Entire Thread
1966 fire truck,19,500 GVW rating, rear brake help
| 57NAPCO | 07/19/2012 6:35 PM |
Re: 1966 fire truck,19,500 GVW rating, rear brake help
| 57NAPCO | 07/21/2012 11:46 AM |
| 53moneypit | 07/21/2012 1:48 PM |
| 3B | 07/21/2012 3:39 PM |
| 57NAPCO | 07/23/2012 9:38 PM |
| Jake45 | 07/24/2012 3:34 PM |
| 57NAPCO | 07/25/2012 8:36 AM | |
