one caution on cutting out as little as possible, you need to cut all the way out past rust pitted metal inside or out. If not welding in new will be more difficult and that is the last thing you need. I purchased rear corners and front cowl inner and outer from Jim Carter door panels from chev of the 40s. I looked for american quality and ask questions. Still had to do work on all to get perfect fit.
