Pplummer,
If you want to check your idea about the rocker arm shafts, you could plug the port feeding the shafts, and then run the engine and see what it does. You could have someone dribble oil over the shafts while you did this to make sure they are getting a little oil.
If you need a hand, I'll come over and help.....
Kurt
