| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | On my 46 I disassembled and cleaned the pan cake at the diff. and it was fine,(shifted diff with a vise grip a few times to loosen it up after many years) . Then I installed all new vac.lines. My vac. rotary valve is a sealed unit and was leaking also. Then while the engine was runing I kept shooting WD-40 in the line and let the vac. suck it up to the valve while fliping the lever around. It stoped leaking bad and now stoped leaking completely! That WD-40 is great stuff! | | |
