The parking lamp has two wires
One green
One black
Plug in a bulb and test each wire with a 12 volt source
The brighter wire will be for the turn signals
The other wire is the park lamp.
Test each side to confirm the colors are correct from side to side.
...pic... Post pictures if you can, let us know what brand harness your using also
Ask as many question as you need. We all learn here
