| | | Forums66 Topics128,180 Posts1,057,165 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,773 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,773 | Very rich running is often caused by a weak ignition.
However, if the vehicle is equiped with a Rochester "B", very rich running is normally caused by warped castings which creates an internal vacuum leak resulting in the power valve always being open.
However, the white tailpipe which many of us knew from childhood to be an indication of a well-tuned engine actually was lead deposits inside the tailpipe. The tailpipe of a vehicle running todays no-lead fuel is black. However, it should not be "sooty".
If the engine is excessively rich, an observer behind the vehicle might guess you are "fogging" for mosquitos.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | |
Entire Thread
Rochester "b" #7004600, what size metering jet?
| mannymoejack | 07/20/2012 12:21 PM |
Re: Rochester "b" #7004600, what size metering jet?
| 51bolt | 07/20/2012 12:42 PM |
| mannymoejack | 07/20/2012 12:49 PM |
| mannymoejack | 07/20/2012 12:57 PM |
| Wrenchbender Ret. | 07/20/2012 2:47 PM |
| Wrenchbender Ret. | 07/20/2012 2:48 PM |
| mannymoejack | 07/20/2012 3:12 PM |
| carbking | 07/20/2012 3:24 PM |
| mannymoejack | 07/20/2012 3:33 PM |
| 51bolt | 07/20/2012 4:11 PM |
| Joe H | 07/20/2012 4:22 PM |
| carbking | 07/20/2012 4:28 PM |
| mannymoejack | 07/20/2012 5:55 PM |
| mannymoejack | 07/20/2012 5:59 PM |
| truckernix | 07/20/2012 6:51 PM |
| 51bolt | 07/20/2012 7:20 PM |
| Pre '68 Dave | 07/20/2012 8:01 PM |
| Bolter2 | 07/20/2012 9:58 PM |
| Joe H | 07/21/2012 11:01 AM |
| mannymoejack | 07/24/2012 11:30 PM |
| Wrenchbender Ret. | 07/25/2012 2:08 PM |
| edski | 07/28/2012 7:43 AM | |
