| | | Forums66 Topics128,151 Posts1,056,990 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy New_Ton, yes you can use the disc/disc master cylinder in a drum/drum application IF you use a resisdual pressure valve for drum brake application (I think 15 p.si.)in each brake circuit. When you convert over to disc brakes you can remove the resisdual pressure valves, I would also add a compensating valve to the system when converting to disc brakes, hope that helps | | |
