Originally Posted by 50chvytrk
Ignition switch is installed, key in off position, and red thick wire is on the bottom terminal. Closest to floor.
I think we're good. Thank you!
Sounds good
Here is what mine looks like
...pic...
Mine is just a 2 position switch
I have seen Post where there was another type that you could remove the key and still go from on to off.
