| | | Forums66 Topics128,209 Posts1,057,464 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Just thinking out loud so someone else may come in and correct my statement but if you are installing the 3.55 gears in a pre 54, you will be using the same carrier so the carrier bearings need not be disturbed. I cannot imagine however getting the pinion bearing off of the old gear and on the new gear and it still being sound. | | |
