1 members (baldeagle),
79
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The difference in the OD case is that it is drilled for the reverse OD kick out. One could drill a case if needed. I suspect you got the main shaft with the OD. I should also say the OD will only work on your 58 trans if the OD is from a 1955-63 trans.
See the USA in your vintage Chevrolet! My Blog | | |
