| | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | There are several videos of multi-piece wheel breakdown on You Tube. The main thing to remember is to get the tire completely deflated so the bead ring can be hammered or pushed away from the rim flange. The tire hammer with the spoon-shaped end on it is a big help here- - - -it is used to strike the tire sidewall just where it meets the edge of the rim, forcing the tire bead away from the flange. If you don't have a dismounting hammer, the base of a bumper jack or a high-lift jack applied to the tire sidewall and lifting against a heavy truck bumper or tractor axle is a good way to dislodge the beads.
Once the tire bead is free all the way around, tap the ring down and remove the split lock ring with a pry bar. Then the bead ring can be removed. Turn the tire/wheel assembly over and knock the bead loose from the other rim flange. The rim should be able to be removed from the center of the tire once the valve stem is pushed back through the slot in the wheel center into the tire. A strong solution of dishwashing liquid and water applied liberally to the bead area makes things slippery and helps the tire bead slip off the wheel. Once the tire is deflated there's no danger to a split rim- - - -the hazardous part is inflating it once the new tire is installed and the rim is assembled. Jerry
