If you're willing to modify your battery box, this one will provide much greater cold cranking power than the stock 6V battery. It's the same one that's used in banks of 4 in older Diesel trucks to provide 24V for starting in cold weather. It won't fit through the hole in the floorboard, so you'll need to change it from underneath.
http://www.batteriesplus.com/product_search/23931-Ultra-Pro-Series-Fleet,-Heavy-Duty-Group-4-Hi-Capacity-6--Volt-Battery-SLI4A.aspx
(The link won't reproduce correctly- - - -do a copy/paste into your browser line at the top of the page!)
This help Jerry?
