The power steering used on the big Chevy TF trucks is the same basic set up as used on the cars and light duty trucks, only bigger. The pump is mounted to the back of the generater, the actuation valve is on the drag link and there is a cylinder attached to the frame and tie rod. Not true power steering, it's power assist.
Mike B
