7 members (1955 1 Series, Gray_Ghost, JW51, Pete1946, 55shaker, Gdads51, 1 invisible),
147
2
Mod | | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Running with zero pressure didn't help it much, but if you did any real damage it would have shown up during the cam break-in run. I always confirm the presence of oil pressure before kicking the RPM up to cam breakin speed. I've found that an engine will run for some time on just the assembly lube, as long as no load is put on the bearings. Drive a new engine 50 feet with no oil pressure, and you can count on bearing damage!
Watch the oil pressure and listen for any expensive noises during the first few miles. An oil and filter change after 500 miles is a good idea- - - -not totally necessary, but the cost of a few quarts of oil and a filter is a drop in the bucket compared to what you've got invested in the engine buildup!
Ring seating- - -Perfect Circle used to reccomend 10 full-throttle accelerations in top gear from 30-50 mph. That procedure loads the compression rings against the cylinder walls with combustion pressure, which helps the rings establish a good running fit with the cylinders. Jerry
