If you're adventuresome you might try connecting your 6v gauge as you normally would with a 6v system. I converted my 55.1 panel to 12v years ago and did nothing with the gauges other than change bulbs. It didn't occur to me that I might have an issue. As they say ignorance is bliss. I put over 100K on the truck after the conversion and never had a problem with 6v gauges running on 12v.
