| | | Forums66 Topics128,268 Posts1,058,396 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have it right. Have it in center when you pull the sector out. Dont disasemble the worm shaft unless absolutely nessesary. They actually use gear lube as a lube. If you replace the seals you can. If its going to leak I use a mixture of chassis grease & gear lube. A lot of guys use John Deere cornhead grease. It supposed to work real good. I will look into it next one I do. You can fill it through the center bolt hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
