9 members (TooMany2count, David Bush, Wayne67vert, Tronman, JW51, Shade Baby, Pre '68 Dave, klhansen, Wally / Montana),
99
3
Mod | | | Forums66 Topics128,051 Posts1,055,714 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85858 08/13/2003 11:28 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I am using a 6v 216 starter on my 12V 261 with 11" clutch flywheel. I had the flywheel custom ground to fit the 6V ring gear and it's all footstomp. I kept the 4/0 cables I had with the six volt starter and it spins so fast the engine is up to idle speed before it even catches. I have run it that way for a few months with no problems. As long as you don't crank it for long enough to get the windings really hot you will be fine.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | |
Entire Thread
Starter differences, 6V and 12V?
| 53 Dumpy | 08/13/2003 1:55 AM |
Re: Starter differences, 6V and 12V?
| rimfire | 08/13/2003 2:22 AM |
| cmayna | 08/13/2003 3:43 AM |
| squeeze | 08/13/2003 5:36 AM |
| 53 Dumpy | 08/13/2003 2:23 PM |
| squeeze | 08/13/2003 2:47 PM |
| Fred T | 08/13/2003 3:04 PM |
| 4ontheFloor | 08/13/2003 11:28 PM |
| 53 Dumpy | 08/17/2003 2:49 AM |
| scdascda | 09/04/2003 6:58 PM | |
