0 members (),
172
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Most people do not stop to realize that the rocker is wider then the valve stem. This makes the rocker only wears at the contact point. If you simply insert a feeler gauge between the valve and rocker the feeler gauge will bridge the wear point and give you a false reading. Unless you know the rockers are not worn you should check for wear and reface each rocker if worn if you want quiet results.
See the USA in your vintage Chevrolet! My Blog | | |
