| | | Forums66 Topics128,276 Posts1,058,440 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the issues with fitting hoods of the 2 series are different .... are you using original hinges Tom? did you start by fitting the hood without springs on the hinges? usually when the back of a TF hood pops up when closed, but it lays correctly without the springs, it's because of worn pivot pins on the hinges - meaning you need at least one new hinge
Bill | | |
