Currently installing T5 from S-10 in 57 with 235. A learning experience. If it's FWD forget it. Must be pickup for shifter to be in right place. If it's newer than 89, probably has electronic speedo. If you're installing modern gauges, no problem. If your speedo is mechanical, it's a big problem. There are world class and non-world class trannys. Drive shaft must be shortened for my 3100. Didn't want to mess with original. Finding the right S-10 shaft is still in progress.Google will get you some good info. Try
www.waywardgarage.com Hope this helps.
