| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I have assembled at least several hundred solid lifter engines, and the rule of thumb I've always used is to set the cold clearance .002" wider than the reccomended hot setting. One exception to the rule than clearances tighten up as the engine heats was on air-cooled Volkswagen engines. The cylinder barrels actually "grow" faster then the pushrods as the engine heats up, and hot-engine valve clearance increases over the cold setting. Jerry
